how do i remove this longitudinal lock in front of tranny?
well after spending a little time cleaning the area near the actuator more carefully i found my leak coming from around the actuator.Can somebody chime in and tell me how to replace the seal and what the p/n is for it so i can order or purchase it to fix.And how complicated is it to remove the actuator and reinstall? Do i need to remove the hard metal line and pull out ? and will i need to bleed the awd lock system afterwords?
hey guys i want to remove the actuator/lock pictured at beginning of thread to replace leaking seal behind it how do i remove the actuator while the tranny and engine are installed on car? what bolts do i remove or what do i do to remove it? as i don't want to risk damaging it.
IHI KING!
For removing the front diff lock, see step #6 in Garrett's C4 engine drop DIY
https://rennlist.com/forums/964-1989...ny-drop.html#6
