View Poll Results: Post Rolling Stall Do You Bumpstart or Keystart?
Bumpstart
8
100.00%
Keystart
0
0%
Voters: 8. You may not vote on this poll
Poll: Bumpstart Versus Keystart After Rolling Stall?
I was wanting to see what you guys tend to do when your car stalls while at speed, say coming off a freeway onto the off-ramp, you clutch in and rest in neutral for a bit and then the engine stalls... do you bumpstart the engine or do you use the starter?
I've heard bumpstarting is bad for soaking the catalytic converter with unspent fuel and thereby shortening its life but sometimes I wonder. It seems easy enough to slip the tranny into third and let out the clutch for a quick restart.
This doesn't happen that often with my car but she is kinda stall happy. I've learned to rev the engine up over 3-4000 rpm and let the engine descend to idle from there while in neutral and that seems to keep the engine from stalling.
Any opinions?
Any opinions?
Mine's started doing it a little lately. I think the ISV is dirty again. It stalls after a long engine brake from freeway speed. I traditionally bump start but shift to a higher gear than the gear used when engine driven. It seems to be smoother.
I think that's nonsense, frankly- if anything, a keystart is more likely to do this in that the ECU may be programmed to enrich the AFR on a keystart but either way I'm not worried about the catalyst's health from such a rare occurrence.
After having the LWF fitted I used to just get a stall when the car was cold just after reversing off the drive. So had to do a key re-start. However, it recently started to stall when approaching a stop (as I came off the gas and pressed the gas and strangely, more so if going up hill). A gentle letting up of the clutch would bump it back in to life.
So, I decided to clean the ISV this weekend:
Didn't stall on the first test drive afterwards, so I'm hoping doing this has helped.
Basically yes. You slot it into a higher gear (say 3rd at 30km/h) and gently let up the clutch. The engine will spin back to life. Don't use a low gear though, or it'll burst into life at 7000rpm or more
I can well remember an occassion earlier this year when three of us rennlisters helped bump start a fellow rennlister's car from a standing start because his starter motor was acting up. After about a hundred yards of not starting, we realized that the engine immobilizer hadn't been cancelled before we set off...
Thanks for all the input guys! Now I won't have to shame myself every time I bumpstart the old gal.
