power streering rack on 89 964
hello gents, i removed my front struts tonight to take to work and install h&r greens. After i removed the passenger side and was cleaning up around the area and i noticed the rubber boot coming from the power stering rack just before the tie rod is torn.Can i get replacement boots and does anyone have a part #? and how hard is it to replace these boots? or do i just leave it until the steering finally gets damaged and replace the rack.Right now i have no issues with my rack no leaks and is working fine.
On a side note after cutting a groove in the shock bracket for brake lines to slip out i had those puppies out in 20min a side just have to replace springs and re install.
Burgled
