Does TSB mod affect resale/collector value of RSA?
I have a 1993 RSA that does not have the distributor ventilation kit installed. Does installing the kit affect the collector value of the car, even this is a Porsche TSB for this model?
I would do the Distributor vent fix asap, and replace the belt. I doubt anyone is going to pay extra for it in it's original state. The belt could break at any time and conceivably screw up the engine.
If I fell backwards into money and saw a RSA with just 500 miles, I'd much prefer to see it with the vent mod indicating a wise owner/mechanic.
RL Technical Advisor
Thanks for the input, guys. That's what I thought. Although my RSA is under 11k miles, I am not much of a collector as opposed to an enthusiast. I don't have it mind to ever sell the car, so I will stick the kit on and not look back. I will post pics of my RSA soon.
That's a great idea. Does it theoretically provide the proper dissipation of heat to the distributor belt, since it's located lower down on the air hose? Also, where did you get that T-piece? I'm assuming it's compatible with the factory distributor ventilation kit that Porsche sells, right?
1 Post
I would assume that the flow of pressurised air through the hose would be slightly less once it reaches the distributor because it is being split.
However, in my case, you'll note that the primary channel is straight through to the distributor; with the secondary channel being angled backwards, much less flow would result there.
The T-piece (or more correctly, Y-piece) is just a generic fitting available from any good plumbing/hardware store.
The ventilation kit is more for the dissipation of the ozone than heat. Ozone is created by sparking within the twin distro.
