Winter rebuild project 4.0 litre c2
Dave,
A less costly option than the approach Colin has suggested is to use a Cargraphic 3.8L kit (including Motronic hotfilm conversion and matching chip).
This way you can at least be sure you have a matched set of components, backed up by extensive development and the dyno sheets to prove.
Although this approach doesn't yield the same results that 9M gets from these engines, at least you can be sure that fueling and ignition is safe and you won't wreck your new engine due to injectors maxxing out etc.
http://www.cargraphic.de/stepone/dat...t_P64_3.8L.pdf
http://www.cargraphic.de/index.php?/...,1049/&start=3
When looking at the power graph this kit -only- yields 10Nm/13HP more than their 3.6L hotfilm conversion. When adding their GT exhaust/header (3.8L kit II) an additional 10Nm is yielded with an additional 15 HP (325HP total).
Biggest difference in price in this approach comes through using Motronic (€ 2.5K hotfilm/chip/injectors) rather than Motec (about £5-5.5K all in ???).
Harald,
Don't get me started on Hot Film & MAF kits. At best the ones that I have seen yielded around 3-5hp more than a custom remapped standard Motronic; at worst they made less power than stock and the engine would not idle correctly. I should probably mention that I had an email from a potential customer in Spain recently who bought a complete 3.8 MAF package from Europe and now has the engine in pieces due to a melted piston....
Dave,
Properly ported means exactly what I said - the ports are reprofiled to maximise air flow without increasing port area. 993VR valves are lighter, 50/43mm dia with 8mm stems against the 964 49/42.5mm with 9mm stems; you need to fit 993 valve guides into the heads to run them. With a sports cam the lower weight reduces valve train loading (increasing reliability) and the larger valve has a greater curtain area which flows more air for any given lift. Optimise the cam events to take advantage of the increased c.a. and you can get more power & torque.
Dave,
Thanks for the replies, that cargraphic package looks like a nice deal.
Dave,
Opinions are very divided on the MAF or hot film option- seems a lot of cash for not much return. Colin, do you need to further machine the heads to accept the 50/43mm valves? And what about clearance for the pistons?
Cheers,
Dave
Dave,
Cheers,
Dave
Well,
It's been longer than I expected but here it is ready to go in.
![](http://m1285.photobucket.com/albumview/albums/daveuxb/image_zps7cf429e9.jpg.html?o=4&newest=1)
3.8 slip fit Mahle cylinders
Je pistons
Dc21 cams
Arp rod bolts
996 turbo oil pump
New exhaust valves and new valve springs.
Ps delete
Clewet single belt pulley conversion
Plastic intake manifold
Rs clutch and fly wheel
New tin
Plenty more bits and while you're in there stuff but I'm glad it's back together.
Now to see if it works.
Je pistons
Dc21 cams
Arp rod bolts
996 turbo oil pump
Ps delete
New tin
Originally Posted by dave964diver:10685195
Well,
Je pistons
Dc21 cams
Arp rod bolts
996 turbo oil pump
Ps delete
New tin
Je pistons
Dc21 cams
Arp rod bolts
996 turbo oil pump
Ps delete
New tin
Keep us updated
As for the 9m 4.0 litre, the 1000-2000rpm issues were eventually pinpointed to a pair of poorly machined prototype high lift race camshafts which had dissimilar timing between the left & right banks. Just goes to show that even if you think you know what you are ordering, you can still be sold a pup....[/QUOTE]
The Alpha -N mode tuning (TPS based mapping) probably did not help...!?
Well,
Je pistons
Dc21 cams
Arp rod bolts
996 turbo oil pump
Ps delete
New tin
Je pistons
Dc21 cams
Arp rod bolts
996 turbo oil pump
Ps delete
New tin
From experience owning a few different race engines, when you mod a few things you need to remap to get full advantage , event with a simple, single cylinder motor run with a carburetor ...nice pictures
Keep sending more,
Originally Posted by dave964diver;10686409
[URL
[URL
![](http://i1285.photobucket.com/albums/a586/daveuxb/image_zpsb64dd38e.jpg)
Hopefully this catches your build before it is too late. Unfortunately you will have a major problem with the heads you have machined because the machine shop has machined the heads totally flat and removed the essential cylinder location lugs on the corners. If you fit these they will shuffle across the tops of the cylinders and at best cause leaks. The only solution I can see is to use an aluminium L-profile "le mans" style sealing rings that locates into the groove of the cylinder and in a freshly machined groove in the heads.
Photo of 9m billet head shows the necessary location lugs.
