Oil Starvation
I've read on this forum and elsewhere that 964's are prone to failure of the 3rd cylinder rod bearing. Further reading uncovered that this is not solely a 964 issue, but stems from the way the oil journals run through the system on 911s with the 3rd cylinder being last in line for oil. The failure mode was oil starvation causing poor oil supply to the 3rd cylinder.
So my question is, in the 911 dry sump setup, how does oil starvation occur??
Is it g-forces around a left or right turn?? Is it low oil supply??
Just wondering what's lurking around the next bend.
Thanks,
Dan
Thanks,
Dan
So...for an engine designed to operate above 7300 at times, what modifications must one make.
Given that yer at Rennspor Re-onion, you might see a few of these engines, huh?
RL Technical Advisor
Unable to attend RR IV so I'm working diligently on our new website.
