964 Forum 1989-1994
RS door card information request
Old 11-13-2011, 01:40 PM
  #31
boxsey911
boxsey911's Avatar
Some finishing pics now that I've put some speakers in, to show how the black door cards work with the rest of the interior.
P.s. For those interested in the weight saving that is achieved by this mod, I weighed the panels:
Standard panel (without woofer) = 4 Kg
RS panel (before adding new speaker) = 1.5 Kg
Old 11-13-2011, 02:24 PM
  #32
ThomasC2
ThomasC2's Avatar
Nice steve. It worked with a washer for the handle cover, didn't it?
Thomas
Old 11-13-2011, 02:40 PM
  #33
boxsey911
boxsey911's Avatar
Thomas
Yes thanks Thomas. I also put a tiny smear of washing up liquid inside the covers to help them slip over as I pressed them on
Old 11-13-2011, 05:09 PM
  #34
geordie
geordie's Avatar
Nice work Steve. Sounds like a great tip from Thomas, too.
Another thread saved to favourites ....
Thanks guys ~
PS Did you use Southbound mounts (rather than Recaro) mounts for your P/P ? Do they (S/bound mounts) offer height adjustment or was there another issue that made them a better choice ? (ie dosh)
Old 11-13-2011, 06:24 PM
  #35
boxsey911
boxsey911's Avatar
Yes Southbound's side mounts. They also supplied the recaro sliders with extra holes ready drilled so that they fit directly to a 964. The side mounts have three holes at the front so that you can set the angle of your seat to suit you. The mounts have been specifically designed by Southbound so that the PP sits as low as possible to maximse headroom (or so they tell me). They also have nuts welded in the side to put the seat belt receiver in. I found by using a longer bolt the receiver could be positioned so that it poked through the hole in the seat so that the standard seat belt fitted snuggly across my lap.
Old 11-13-2011, 08:17 PM
  #36
christallon
christallon's Avatar
The Black & Burgundy interior is the Biz Steve. Nicely done!!!
Old 11-14-2011, 03:32 AM
  #37
geordie
geordie's Avatar
Appreciate the info Steve - thanks!
Quick Reply: RS door card information request
