964 Forum 1989-1994
Engine Mount Broke
Old 09-09-2011, 10:22 AM
  #46
Laker
Laker's Avatar
Originally Posted by 1stAutos
No, unfourtunately the motor mount is not covered under the terms of the Limited Warranty....
...I feel bad about it and had no ill-will intended. At the time that I got these mounts there was a discussion about them and some Rennlisters....noted the sub-par quality....
Furthermore, for anyone else considering cheap E-bay mounts I would not recommend it for obvious reasons, and they really were not that much cheaper, btw they are or were advertised as OEM.
Kudos for admitting his warranty doesnt cover the engine falling out, passing the buck and shrugging?
Furthermore, anyone considering doing business with this guy after learning how he does business, should have their head examined.
Old 09-09-2011, 08:13 PM
  #47
AOW162435
Seared
AOW162435's Avatar
OE and OEM are not the same things.
Andreas
Old 09-09-2011, 11:45 PM
  #48
campoj2
campoj2's Avatar
For a couple of hundred bucks you could have a customer that raves about the support he received from this dealer, and most likely recommend this dealer to friends & family, in the end, the dealer will pass the buck -
I find it ironic that the mounts failed so quickly after they were installed - hell, if I was the dealer I would utterly embarrassed that I bought parts for a car and they failed with 2 weeks after installation - The DEALER picked the parts supplier - why? Because it was probably the cheapest mounts he could find -
Whiskey Tango Foxtrot?
Old 09-15-2011, 06:33 PM
  #49
chris951
chris951's Avatar
The dealer offered to reimburse me for both new engine mounts. Thanks for the help guys!
Old 09-15-2011, 08:26 PM
  #50
anto1150
anto1150's Avatar
Old 09-15-2011, 08:50 PM
  #51
Babalouie
Babalouie's Avatar
Good to see it worked out...also is a good warning not to buy el-cheapo engine mounts
Old 09-15-2011, 09:25 PM
  #52
chris951
chris951's Avatar
Don't buy el-cheapo any parts for your Porsche, you get what you pay for.
Old 04-29-2020, 05:32 PM
  #53
nabfa1
nabfa1's Avatar
Small questions if I may
So the two rear engine mounts are needing to be replaced ..... should the third "front" between the transmission and transmission crossmember be also changed in " good measure " so all are new.... or would the third one be an extreme pain to replace ? Insight always always appreciated.
Old 04-30-2020, 10:59 AM
  #54
911Jetta
911Jetta's Avatar
Wow, new motor mounts will really tighten things up! Usually the transmission mount is in much better condition and doesn't need to be replaced with the same frequency as the motor mounts, but you'll have to inspect to ensure their condition.
Old 04-30-2020, 11:04 AM
  #55
Spyerx
Spyerx's Avatar
Received 1,807 Likes on 1,102 Posts
I’ve all 3 in good used condition for sale.
the transmission one has to be pressed out. May be tough with transmission in the car.
Old 05-03-2020, 09:43 AM
  #56
nabfa1
nabfa1's Avatar
Thank you thank you !!!!! What would I do without this forum Honest .
F.
Quick Reply: Engine Mount Broke
