Heater blower bypass: Tube vs. Plate
Claudia lost her A/C and heater blower yesterday in our quest to lighten her load.
The other day I ordered a blockoff plate from Rennline prior to checking in with my guru, advisor and all around good guy (btw, I do order everything I can from him), Herr Weiner. Made a mistake, and I'm glad he caught it.
If we are not running headers without heat exchangers, we must use the bypass tube - not the pretty plate. Steve tells me the exchangers need air flow from the tube or we run the risk of over heating that section of the engine and compartment. I know some have done just this (used the plate), but it is an avoidable mistake.
So, if we have heat exchangers and want to do away with the heater blower, we must use the tube...lesson learned. The pretty plate will have to wait until the engine is built up next year.
btw: Don't believe everything you read. I estimate the heater blower's weight at three pounds and the a/c compressor plus its engine compartment lines at perhaps twelve - total weight removed around fifteen tops.
My heater blower motor and pipes weighed 5.25 lbs... (I had read a couple times it was 5+ lbs.)
Don't forget to the AC components up front, there's another 10+ lbs. when you remove the fan & evaporator from the front fender. (I've read that removing the complete system is worth about 30+ lbs)
+1 on the air con condensor up front being heavy. Get it and the rest of the pipes that feed it, out, if you've already taken the other aircon stuff out of the engine bay.
Among other mods to include a Motion Control Suspension from Rennsport Systems and a few other goodies.
I will weigh the heater blower on 'Lil Audrey's baking scale when I get the chance to upwrap it.
Super Duper Moderator
i know myself and others would really like a definitive statement on this issue as I have the block off plate, with heat exchangers. I haven't noticed anything odd yet, but it makes sense that these things could get too hot and cause issues.
He's never given it a second thought. Says the stock exhaust and exchangers are good stock and sure they'll get hotter, but has not seen a problem with the block plate. Says Weiner has a point; I do know Steve to be conservative and can't disagree with him on anything so far.
(btw, Gamroth has the 430hp engine mounted up and says the car is a monster. Has another on the dyno right now and a third in the engine room.)
I'm going to use the tube, as Ian has one coming to me - my plate can wait until the RSR build.
