Educate me on brake calipers
#31
Remove the proportioning valve instead of buying the 55 bar version as they did on Cup cars. I did it 3 years ago without any downsides. the car is much more stable under heavy braking and the pad wear is more even.
It's easy to do, just remove the valve and connect the two pipes with each other. You can bend the pipes gently with your hands to make them line up.
Thomas
Thomas
Has anyone else done this? Any feedback? Expectations? Horror stories?
I can imagine there would be an increase in braking power, but would you really start to lock up the rear tires under heavy braking? Would having wider tires in the rear (lets say 255's
Sorry for all the questions, but I am in the midst of putting the 4piston calipers onto my rear, and this p/v topic definitely has me snooping around. I'm just not sure I can get a 55 bar valve in time for Laguna Seca, and I definitely don't want to have any unpleasant surprises at the track ...
#32
Super Duper Moderator
Yep - did this last year. Very easy to do.
Car is much more balanced on braking and stable with trail braking.
Marc
(see my sig link for brake setup details which is far from stock!).
Marc
Marc
Marc
#34
#36
Perhaps think about an adjustable Tilton rear bias valve.
You're not limited by a race classification, it's tremendously inexpensive, infinitely adjustable and very easy to install.
#37
#38
#42
Garrett did the same thing on his C4 race car here (and it was 6 years ago, not last year - wow, how time flies!).
Marc
#43
When you read the one link, you can see how folks are saying that the delete is not the best idea for stock brake set up ...
what can one (me) expect if I have the stock calipers up front and "upgraded" C2/4 4 pods in the back?
#44
Ok guys, so i'm checking back in on this one ...
With the addition of 4 pod calipers in the read, the deletion of the p/v valve was a great contributor in braking ability and modulation. I was expecting the back brakes to lock up, but nothing of the such ever happened. A big
Thanks for all the advice, here's a picture for you guys to enjoy ...
