How to turn in oil cooler fan by 212F?
Interesting mod but confused if it is really needed. After having my motor rebuilt recently (Performance Auto) I talked to Peter, who does the rebulds, concerning this temp issue and if a mod or remote switch is needed to keep things cool.
He stated the low speed fan engages at 200 degrees and high speed around 220. This seems about right as my temp runs right at the 8 o-clock mark (194) during normal driving and on hot days when it creeps past that mark...it drops as the fan kicks on.
Just my observation...any more feedback would be great.
nabfa1 (07-08-2023)
I'm in Texas, 100+ degrees for most of this summer, and whenever I end up having to sit in traffic, my temp will shoot up to almost 10:00 (248 degrees) then it'll stay somewhere between 9-10:00 until I start moving again.
I plan on doing this mod, I already purchased the resistors, I just haven't taken the time to remove the bumper since I also want to replace the front grille and maybe install some fog light ducts all at the same time so that i'm not removing the bumper a bunch of times.
Thank you for the pics!
nabfa1 (07-08-2023)
Laker,
Have you tested the mod via a laser temp gauge? I shot my cooler with a laser temp gauge and the first speed would kick on around 230F without this mod.
I am preparing to do the same mod and would like to know your results.
Thanks,
Jim
Thanks,
Jim
nabfa1 (07-08-2023)
It won't get hot from any electrical current. This is a signal wire with low ampere / watts running through it. That's why you don't have a fuse in this line either.
Soldering the resistor on this end is less risky than on the CCU side if you don't solder very often. Soldering to CCU board can create $500 - $1000 damage from the soldering heat. If you fry the plug on the other end, it will be less expensive....
I'm thinking of doing this mod, but soldering the resistor between G12 and G18 of the CCU PCB. Remove the CCU from the dash, remove the PCB's from the CCU case, solder the resistor to the outside of the board - no need to split the PCB's.
