964 Forum 1989-1994
Wheel / tire size question
Old 05-31-2011 | 05:12 PM
D.C.'s Avatar
D.C.
Default Wheel / tire size question
I have searched, but have not found an answer. I think this is an easy one.
will these wheels.
Front:
17x7.5
Offset: 52mm
Rear:
17x9
Offset: 47mm
Fit on my standard body 1991 964?
What is the best tire size to use?
Do I need spaces? If so what size?
Thanks in advance....
Dave
Old 05-31-2011 | 06:17 PM
KaiB's Avatar
KaiB
They should fit right in without problem...but
I have essentially the same wheels, built new, and they don't fit properly as the wheel halves (rear only) aren't right. The wheels fit, but do not fill the outside of the well and flat don't look right - and loose me 2" of track.
Do you know the measurements for the rest of the wheel build?
Old 05-31-2011 | 08:08 PM
crg53's Avatar
crg53
That is the size I have on my car with 225/45/17 front 255/40/17 rear, no spacers needed.
Old 05-31-2011 | 08:35 PM
sml's Avatar
sml
if you want to understand and calculate yourself then try this ...
https://rennlist.com/forums/964-foru...el-offset.html
Old 05-31-2011 | 08:39 PM
sml's Avatar
sml
btw ... there is no need to tell us the diameter (ie 17") for checking offset, so just search for 7.5ET52 and 9ET47 and see what turns up in the threads here.
Old 06-01-2011 | 12:09 PM
D.C.'s Avatar
D.C.
KaiB - I do not know the measurements for the rest of the wheel build? I am looking at a set of Cup 1 wheels that are aftermarket, the seller told me he bought them at tire rack.
Steen - Nice car! That is the look I am trying to achieve. Are those Cup 1 wheels. I am looking for a set.
SML - Thanks for the link(s). Would you be located by chance at Smith Mountain Lake (SML)?
Dave
Old 06-01-2011 | 12:29 PM
911Jetta's Avatar
911Jetta
Originally Posted by D.C.
Front:
17x7.5
Offset: 52mm
Rear:
17x9
Offset: 47mm
I also have Tire Rack reps (not Cup1 style you are looking for, TR replaced those with something they call Cup 4...uses 996 Turbo style cues - with edges).
That said, it's the same size and offset your are considering. Perfect fit.
Do you have a C2 or C4?
If a C4, I'd go with a 225 front to reduce understeer.
If a C2..you could go either way (205 or 225) depending on the handling balance you are looking for. Mostly street use right?
Old 06-01-2011 | 01:58 PM
crg53's Avatar
crg53
Dave
Thanks, yes those are Cup 1's but Mille Miglia replica's. The car is lowered to RS +5 m/m ride height with H&R Green springs and Bilstein HD dampers, alignment is also RS.
Old 06-01-2011 | 02:14 PM
KaiB's Avatar
KaiB
I don't know what I was thinking; it's the wheel half dimensions that define the offset. You're in a perfect fit. 205/45 or 225/45 front and 255/40 rear will serve you well.
Old 06-01-2011 | 02:39 PM
911Jetta's Avatar
911Jetta
Originally Posted by KaiB
[B]...I don't know what I was thinking; it's the wheel half dimensions that define the offset. You're in a perfect fit. 205/45 or 225/45 front and 255/40 rear will serve you well.
Isn't it...205/50?
Old 06-01-2011 | 02:57 PM
KaiB's Avatar
KaiB
Originally Posted by 911Jetta
Isn't it...205/50?
225/45 front will serve him well on those rims w/255/40 in the rear.
Old 06-01-2011 | 03:02 PM
911Jetta's Avatar
911Jetta
^^^ I know.
However to be clear, look for a 50 aspect tire if you go 205. (not 205/45)
Old 06-01-2011 | 03:36 PM
KaiB's Avatar
KaiB
^^^ I know.
Typo - oopsie...It's a good thing I have adult supervision here.
Old 06-01-2011 | 06:21 PM
Earlydays's Avatar
Earlydays
The factory specs for 17" are as follows:
RS America 7J-ET 55, 8J-ET 52
Carrera RS 7.5J-ET 55, 9J-ET 55
Up to a point different offsets can be used with the appropriate spacers.
Old 06-01-2011 | 08:40 PM
Otto Bonn's Avatar
Otto Bonn
Dave,
There is also supposed to be a 10 mm steering spacer installed when going from 16" to 17" . I assume this is what you are doing.
225 front, 255 rear should be no problem. 265 35 rear should work too. Bigger can fit but...
Quick Reply: Wheel / tire size question
