964 Forum 1989-1994
Rear center reflector
Old May 25, 2011 | 01:11 AM
glu1973's Avatar
glu1973
6th Gear
Default Rear center reflector
In Europa the rear center reflector are hard do find, I have contacted several suppliers including Porsche, but no one have them in stock. In US however this is not a problem, several suppliers have them in stock. But the US reflectors have a different part number. Does anyone no if there really is any physical differences between the European and the US versions?
The US part number is 964 631 160 00 and the European part number is 964 631 159 00.
Geir L.
Norway
Old May 25, 2011 | 01:29 AM
ozmatt964's Avatar
ozmatt964
Try Design 911, that where I got mine last year. (No affiliation)
Old May 25, 2011 | 01:50 AM
Silvertarga's Avatar
Silvertarga
Euro Model has four bulbs ...US model has two
Old May 25, 2011 | 06:23 AM
deutschland-dobson's Avatar
deutschland-dobson
Yes, as said the US model doesnt have the fog lights fitted where as the Euro one does.
I have a US one fitted at the moment and I think it would be easy to adapt to fit the remaining two bulbs, however I cant bring myself to try in case I damage the unit!
I just swap it over at MOT time
Chris
Old May 25, 2011 | 06:28 AM
gprosser's Avatar
gprosser
these guys have new and used examples: http://www.teile.pl/
not bought off them, but have just received an email confirming this
€120 for left and right, €204 for centre. think that's for the used set though - getting a quote for new set now.
Rgds, Gareth
Old May 25, 2011 | 05:59 PM
Kuchar's Avatar
Kuchar
I also recommend teile.pl. You can often buy parts from them, which nobody else has.
Old May 25, 2011 | 06:50 PM
boots's Avatar
boots
Hi all,first post
i got one of these recently sent by porsche by mistake,usa has no fog lights or wiring for them,holes arent there either
try gert at carnewal...best i have dealt with
Old May 26, 2011 | 05:58 AM
deutschland-dobson
Hole markers are there, so wouldnt be too hard to cut. If you have a UK car then the wiring and the bulb holders would then fit from the car into said holes
Chris
Old May 26, 2011 | 09:41 AM
glu1973's Avatar
glu1973
6th Gear
A brand new reflector (European version) is on it's way to Norway. Found it here: www.type911.co.uk
Old May 27, 2011 | 07:32 PM
boots's Avatar
boots
Chris
correct,but when bought new easier to get porsche to give you the one you asked for.you need to remove wiring from your old unit,you are only short one switch wire
Old May 27, 2011 | 08:12 PM
Silvertarga
I drilled mine out and then did the close finish work with a soldering pen...less crud to fill the reflector that way
