OBD1 - Picture request
Just wondering if anyone has any photos of the OBD1 connector in situ under the seat?
I've had a search through loads of old threads but can't find any pictures.
I'm interested to see exactly where it's located and what it connects or splices into - does it connect into the main engine harness leading into the ECU?
Hi rarebear, thanks for the reply - Do you know exactly where the OBD1 connects into the harness?
I was also trying to figure out if all 964's had OBD1 connectors fitted as standard?
afaik all 964's had OBD as standard, correct e if I am wrog
afaik all 964's had OBD as standard, correct e if I am wrong ,
see picture of the (hard to obtain) 19 pin male to 16 pin OBD2 female connector
What information can be garnished off the plug? Can it find problems before they are felt in the seat of their pants? Any OBD-1 urban legends/success stories about engines saved because of a random diagnostic check or no-start symptoms solved by a simple diagnostic run??
Just curious.
Just curious.
Don't believe that would work. A few very smart people here on RL put 100s of hours building circuit boards needed to communicate with the 964. They certainly would have gone the dual connector route if it would have worked.
Just curious.
Just curious.
http://members.rennlist.com/jfk964/bw_faultcodes.htm
Thanks for all the replies chaps ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I've looked into it a little bit and I don't think the OBD1 to OBD2 connector that you can buy from fleabay works for an application like this (otherwise we'd all be doing it!)
My 964 loom doesn't have an OBD1 connector but it has been chopped around a bit in the past!!
I do have an OBD1 connector (see photo below) which is why I wanted to see the under-seat view and exactly where it connects to the loom.
Anyone got a good under-seat photo to help me out?
It does work for some early OBD1 vehicles if the reader can pick up and decode the unit. As far as I know it do not, however, work for a Porsche. The OBDII scan too wont read the Porsche DME.
Here's info on what you can learn:
I have a 91 and it does not work mine is too early for the up dated OBDI
Aha, thanks Laker. I always thought it was under the seat!
Drawn a blank on the wiring though. As I said, the loom has been chopped around a bit. Here's a couple of pics before it was fitted.
