94 964 CCU
8th Gear
94 964 CCU
The A/C on my 94 964 has been giving problems over the past years. Refrigerant recharge every spring has helped, but about a year ago my temp. regulation on the CCU has gone bad. When not using A/C, if I put the dial on the blue setting I get cool air. If I move it just a bit off the blue dot setting I immediately get max heat....there is no regulation as I move the dial to hotter temps. If I turn on the A/C, it will blow cold air if the dial is on the blue dot...moving it off the blue dot at all gives max heat. Just had refrigerant put in and when driving the A/C is nice and cold, but about every five minutes I get a blast of hot air come through the vents. This just lasts for about 10-15 seconds and then it goes back to cold air. I noticed when sitting at idle, the compressor seemed to kick in and out occasionally. Suspecting the CCU unit is bad. Has anyone replaced the whole CCU unit..and if so, what was the cost of a replacement unit. Can they be repaired? Would like to get this resolved once and for all.
I suggest you diagnose the problem. I dont think you will solve it only by replacing the CCU. There are lots of thing that can go bad.
Start by reading this:
http://privat.bluezone.no/toreb2000/ccurepair.html
I can tell you that a while back, before this problem, I purchased a used "non-working" CCU, just because it was a good price for a spare, and I have tried all combinations of exchanging entire unit, face with electronic board, just the board, and the body of the units with no effect on this problem. Makes me think it has to be a problem with modulation by the servos, but I can't figure out what would make them act in unison other than the CCU. ??????????????
IHI KING!
Can the CCU be repaired? Yes. I've had mine repaired by Loren (http://www.systemsc.com/products.htm). He was very responsive and the CCU worked perfectly. He has some good FAQ troubleshooting steps on his site. Try those first.
No affiliations.
No affiliations.
if you have access to a Scantool, it would be best to check for faults and review the TSB.
Apparently Porsche Dealers were also too anxious to replace the CCU
I have them uploaded on this post
my guess is a bad temp. sensor
Last edited by Laker; 05-12-2011 at 01:31 PM. Reason: added direct link - thanks Rob!
IHI KING!
I have them uploaded on this thread, Post # 274
https://rennlist.com/forums/964-foru...embled-19.html
https://rennlist.com/forums/964-foru...ed-19.html#274
