Jack points
Dec 20, 2011 | 10:40 PM
Quote:
Originally Posted by
altarchsa
He also has the "block the wife from interfering" rotisserie position against the garage door.
I learn valuable things here.
Dec 22, 2011 | 08:20 PM
Just a quick caution. On the passenger side rear be careful if you use the outer most part of the jacking location. It is right next to the oil tank drain plug. You can damage the tank if you catch the plug with the edge of the jack when you lift the car. I lift at the innner part of the jack point and put the jack stand in the same place so it's out of the way when I drain the tank.
Dec 23, 2011 | 12:35 PM
Good point. I'll watch for that.
how do you get the jack out and the jack stand in? just do it real fast?
Dec 23, 2011 | 12:58 PM
c didy
I make my girlfriend hold the car up while I swap.
Apr 22, 2014 | 02:17 AM
Just doing a little research. I'm missing the driver's front jacking point. Where do I buy its replacement?
Apr 22, 2014 | 03:03 AM
Porsche have them in stock, I havent seen anybody else doing them yet.
Part numbers front
Left 964 501 297 00
Right 964 501 298 00
Rear numbers
Left 964 502 085 00
Right 964 502 086 00
Apr 22, 2014 | 11:52 AM
thanks for the part numbers
Left 964 501 297 00
is the drive side right? I need new jack point too
Apr 22, 2014 | 12:26 PM
yep drivers side is right, will be followed by GRV
£39.33 plus vat for each front from porsche
Apr 22, 2014 | 04:35 PM
Apr 22, 2014 | 05:43 PM
Apr 22, 2014 | 05:44 PM
I won't embarrass myself by showing you the after welding photo's!!
Apr 22, 2014 | 05:51 PM
2002 ,
2004 ,
911sc ,
964 ,
997 ,
bent ,
cayman ,
dodge ,
front ,
jack ,
jacking ,
point ,
points ,
porsche ,
ram
