Source for Oil cooler hoses
So I have have to tackle the dreaded weeping oil lines....where is the best place to buy the lines that go from the front oil cooler to the thermostat? I would love to never have to touch these again....
quick pic for your enjoyment....
Burgled
some places can make up the hoses for you cheaper then the golden Porsche part. Check a local hydraulic shop and maybe they can help you out. They arent cheap!!
Super Duper Moderator
964-207-133-04-M20 $283.75 1 $283.75
Oil Line, Left Side of Oil Thermostat to Front Oil Cooler, Outer
Fitting, 911 Carrera 2/4 (1989-94), 911 Turbo (1991-94), Each - Brand:
Cohline
964-207-135-04-M20 $287.00 1 $287.00
Oil Line, Right Side Of Oil Thermostat To Front Oil Cooler, Inner
Cohline
I am pretty sure these are the parts from my email (but check part numbers before ordering!).
Marc
For half of the best price I could find on new ones I had mine rebuilt at a local hydraulic hose shop (replaced the flex line, re-used the hardline). They are perfect now.
The down side was that with the hoses leak-free, it showed up another leak from a crack in the oil cooler! Since I replaced the cooler everything is clean and dry in that area.![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Good luck!
Jim G.
Good luck!
Jim G.
