Trying to adjust valves
Trying to get the valves adjusted and belts changed on my C2. When I turn the nut in front of the pulley, it spins the pulley, not anything else. It seems that maybe I should tighten the bolt and the triple square thread for the alternator, will that allow me to turn the crank? Am I going at it all wrong? Usually I don't get beat by simple things, since I haven't done it on a 911, I want to be sure it is done right.
TIA for your help.
Brian
TIA for your help.
Brian
If I understand you right, you are using the nut on the alternator shaft to turn the engine, but only the nut/pulley and shaft turns. There are 2 pulleys and 2 belts, one turns the altenator the other turns the fan, they are independent of each other. I use a wrench on the nut and push on the belt with my other hand to turn the engine, or you can just grab the pulley with both hands pushing in on the belt at the same time, rock it back and forth to get passed TDC until Z1 it lined up.
Hope this makes sense to you.
+1 - Remove the spark plugs (ie vent the cylinders so you are not working against the compression stroke). The other thing I do, is pinch the fan belt as I try to turn the pulley, it gives the belt more tention.
I have a friend who has a very strange looking ring finger on his right hand, as he lost half of it in an A/C pulley. He got too close and it plucked it right off. He got it sewn back on, but it sure looks strange.
