964 Forum 1989-1994
front hood struts the easier way
Old 10-01-2014, 12:51 PM
bizun123
Cruisin'
bizun123's Avatar
Morning. Checked the bracket and the lights. Everything working as it should be. Thanks for the idea. Back to the drawing board for me.
Old 10-01-2014, 02:05 PM
jimq
Burgled
jimq's Avatar
I just unplug my light. If I need it its simple to plug back in. Never have to worry about it.
Old 10-02-2014, 04:52 AM
Mark Brook
Mark Brook's Avatar
Pull the bulb out of your light, then at least you can discount it as the source of the drain.
Old 10-02-2014, 01:39 PM
bizun123
Cruisin'
bizun123's Avatar
I don't think it can be the light. Even when it's disconnected there's still a drain. Just have to start working backward from the battery and trying to find the short/gremlin.
Old 10-09-2014, 04:20 PM
bizun123
Cruisin'
bizun123's Avatar
So I have an update...turns out that the short was nothing more than coincidence to my strut replacement. Apparently the starter wire was rubbing the heat exchanger coiling and causing a 15amp draw. Repositioned the wire and wrapped it up. No further problems. Thanks again to all for the ideas and advice.
Old 10-09-2014, 07:53 PM
dhc905
dhc905's Avatar
So to get back to the strut replacement - am I essentially using the top of the strut to leverage against the Dowel (which I can't fit between the hose and the strut anyway) and prying it lose at the bottom?
I have to believe there is something holding it in place at the bottom...
Old 10-10-2014, 01:42 AM
carlskisWP
carlskisWP's Avatar
You may already know this, but just in case: There is a retainer clip that slides into the lower ball that stops the ball from popping off the post.
Check the pics in this thread
https://rennlist.com/forums/964-1989...od-shocks.html
After the clip was out it didn't take too much force with a long screwdriver to get the ball to pop off the post.
Old 10-13-2015, 04:40 PM
kkozski
kkozski's Avatar
Thanks again for walking me through another repair. So tired of carrying around an adjustable ski pole to hold hood open. I used a sturdy wooden spoon handle to pop off and pop on the lower strut end. To loosen the clip for easier popping on, I slipped in the end of a length of steel wire that I then pulled out from above after popping it on with spoon handle. I will admit it took me longer than 15 minutes, but most of it was finding "tools."
Old 10-13-2015, 06:11 PM
Earlydays
Earlydays's Avatar
The rear struts are more "fun"!
Old 10-13-2015, 06:41 PM
pcarplayer
pcarplayer's Avatar
Worth removing half the airbox and the heater blower when replacing the rears. Also invest in a pair of extra length needle no pliers. Alternatively, use a Turbo struts and just do one side. The left hand side is much easier. The Turbo strut is more powerful as it needs to support the spolier
Old 01-20-2021, 08:51 PM
Fwdc2
Fwdc2's Avatar
This was really helpful. Changed mine the last time probably almost 20 yrs ago and could not figure out how I got them loose. This was quick and super easy!!
The following 2 users liked this post by Fwdc2:
9SIX4-C4 (01-21-2021), mark lintott (05-31-2022)
Old 05-25-2022, 08:25 AM
cbracerx
cbracerx's Avatar
Dowel approach for the win. Worked like a charm.
Old 05-29-2022, 10:47 AM
ALSPEAKE
ALSPEAKE's Avatar
For removing and refitting the rear struts I made up this little tool it takes a moment to slide into the clip follow through and the clip comes off the pin and stays on the tool.
Rocket Rob (06-04-2022)
Quick Reply: front hood struts the easier way
