I most certainly will. The suspension should be done this week and Jeff has promised photos as things move along. The Jongbloeds cannot be built until the suspension and brakes are done(ish) as the caliper clearance must be measured.
I did mine in satin black, I like it. It was pretty before I put the padding on, now it mostly looks like padding and zip-ties...
Which is as it should be. After my rollover last fall (as a passenger), I can't imagine having an unhelmeted head anywhere near unpadded tubing. Your body goes place you can't even imagine; and this was at ~25MPH.
Anyway, here's red nakedness in the '73 chassis that has a simple cage.
