964 Forum 1989-1994
Oil overflow?
Old Feb 27, 2011 | 11:18 PM
Idiot964Owner's Avatar
Idiot964Owner
Default Oil overflow?
A couple of weeks ago the alternator died on me and I had it towed to my usual local garage to have it fixed (still looking for a porsche specialist) and I checked the oil today and the oil mark was at, well its hard to describe so I'll draw a picture.
I remember there being two rivets and then there were two other markers on each side mine is over the second rivet thats why im a bit worried, I've been driving it alot recently (a bit hard if i may say ) it seems like the guys may have given it to much oil.
I'm not to mechanically inclined but I think i should be able to handle and oil change this could also explain my oil leak.
Also what is a good oil choice to put in a 964 C2? During the winter it is usually high 20s to mid 30s and in the summer it can be anywhere from 80-95.
edit: My oil temperature and pressure appears to be normal but during idle the line is a bit above the top marker on the reservoir gauge though I never really trusted it.
Old Feb 28, 2011 | 01:41 AM
stevepaa's Avatar
stevepaa
The gauge is the trusted source. Drain a little off until it reads halfway.
Old Feb 28, 2011 | 02:48 AM
Idiot964Owner
And uhh whats the easiest way to accomplish that?
Old Feb 28, 2011 | 06:59 AM
sml's Avatar
sml
FWIW .. I pushed my gauge to about 3/4 full and worried that it might be overfilled, I had read about guys having success with a turkey baster in the oil fill pipe.
I tried pushing a thin clean hose about 1m into the oil fill pipe and couldn't even touch the oil.
I have no idea how the turkey baster thing worked unless it was way overfilled.
Maybe loosening the oil tank bolt or engine case bolt would be easier?
Old Feb 28, 2011 | 08:31 AM
jimq's Avatar
jimq
Burgled
buy one of those cheap plastic pumps you hook on a drill and pump it out. The thin plastic hose goes right in the tank. I use one to change the oil in my boat motor.
Old Feb 28, 2011 | 09:14 AM
sml's Avatar
sml
how do you do that? I pushed about 1 metre of hose into the oil fill tube and never touched oil.
Old Feb 28, 2011 | 10:41 AM
bmohr's Avatar
bmohr
gotta go around the little bend and it will touch oil trust me.
Old Feb 28, 2011 | 11:49 AM
crg53's Avatar
crg53
The gauge is electric/mechanical and can easily be off, the dipstick is your best source of accurate oil level. FWIW I fill my car to half way between the marks on the dipstick, at that level the gauge shows half or 3 o'clock.
Old Feb 28, 2011 | 11:54 AM
stevepaa's Avatar
stevepaa
I had to do this last weekend. When cold, put a pan under the drain of the thermostat and gently unscrew the plug but hold it in place and let about a pint out past your hands and then rescrew it in. You can wear plastic gloves to minimize exposure on your hands.
Old Feb 28, 2011 | 11:58 AM
darth's Avatar
darth
I rely on the dipstick as being the true reading. Learn how to read it and there will be no doubt as to the oil level which the guage can create if there is a poor electrical connection, defective sending unit or guage. There's not much oil in the engine and a minimal amount can be removed from the engine drain plug. I'd be hesitant in putting anything (i.e. a tube/turkey baster) other than air, fuel or oil into the engine.
Old Feb 28, 2011 | 01:15 PM
Laker's Avatar
Laker
go to a pet store and get 6 feet of air line tubing. ($2) use that to siphon oil from the dipstick... slow, yes, but cheap and reliable
Old Feb 28, 2011 | 03:16 PM
Idiot964Owner
I'm just going to change it myself it looks like he used a cheap crappy oil filter too
What are some recommended oil brands and types im not to knowledgeable on the whole viscosity ratings and what not.
Old Feb 28, 2011 | 03:25 PM
altarchsa's Avatar
altarchsa
Do a search. Lots of opinions and posts on this.
Old Feb 28, 2011 | 03:28 PM
stevepaa's Avatar
stevepaa
Old Feb 28, 2011 | 04:23 PM
Bearclaw's Avatar
Bearclaw
From: Seattle xburb - I can't see the Emerald City, but I know it's out there somewhere
http://www.bobistheoilguy.com/forums...Board=1&page=1
Do a search on "Porsche" here too. Good place to go if you're unclear on the basics of automotive motor oil. Just be prepared to do about a week's worth of reading.
