964 Forum 1989-1994
964 dimensions needed
Old Feb 24, 2011 | 10:49 PM
Mike Hall's Avatar
Mike Hall
Default 964 dimensions needed
Does anyone have a diagram of the dimensions of a 92 964 C2? I just bought a car that has a bit of frame damage on the driver side and I am looking for some dimensions to go by when pulling it back into place. The damage is minor and only a slight bulge is in the frame just behind the shock tower. I am going to check off some points whiling pulling the frame back into place and I wanted accurate numbers to go by. Any help with this would be great.
Mike
Old Feb 24, 2011 | 11:13 PM
ian89C4's Avatar
ian89C4
see if this helps:
http://www.porsche964.co.uk/technical/wgts.htm
Old Feb 25, 2011 | 12:18 AM
mojorizing's Avatar
mojorizing
Mike,
What you need is in Vol 5 of the Workshop manual. It shows the various dimensions of the under body from take up hole to take up hole. I can't upload the screen shots of the pertinent pages due to the fact that I'm behind a corporate server and it won't allow me. If no one can supply the diagrams, pm me your mailing address and I'll mail them to you. I'm in a remote area off of Alaska working on a project so give it some mail time.
Old Feb 25, 2011 | 12:26 AM
Makmov's Avatar
Makmov
Old Feb 25, 2011 | 12:33 AM
Makmov's Avatar
Makmov
If you have an email I have the pages you need in a PDF. Othewise my print screens are small.
Old Feb 25, 2011 | 12:38 AM
Makmov's Avatar
Makmov
Ah ha! I figued it out.
File Type: pdf
Old Feb 25, 2011 | 12:39 AM
Makmov's Avatar
Makmov
Or maybe not.
Old Feb 25, 2011 | 12:40 AM
Makmov's Avatar
Makmov
I guess that is best I can do.
Old Feb 25, 2011 | 12:48 AM
Makmov's Avatar
Makmov
Old Feb 25, 2011 | 12:50 AM
Makmov's Avatar
Makmov
Old Feb 25, 2011 | 12:52 AM
Makmov's Avatar
Makmov
Old Feb 25, 2011 | 10:51 AM
Mike Hall's Avatar
Mike Hall
Perfect. Thanks for this man. This is just what I was looking for.
Mike
Old Feb 25, 2011 | 11:39 AM
Makmov's Avatar
Makmov
Mike
NP
They are for a C4 but I can't imagine that they are that much different.
When I get home tonight I will look to see if I have the C2 dimensions.
Old Feb 25, 2011 | 09:24 PM
Makmov's Avatar
Makmov
They must be all the same because there was no futher control point data for any of the other cars (RS, cab, turbo) in the appendex.
