What is this?
Probably an aftermarket alarm that has been disconnected or removed. My car interestingly has one in the same place. I also notice you have an led between the tach and the speedo, also like mine, which was used for a built in radar detector. My on/off volume **** is directly below on the underside of the gauge panel, pointing down. I think these might have been common dealer installed items when these cars came out. Imagine buying a 70k car without an alarm?! Obviously, they do have a horn honk and fuel pump cut off from the factory, but no shock or tilt sensors.
+1
That's really funny... all mine has left there is the hole.![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
Oh - that, and a cut wire poking out from where the side of the dash meets the door pillar, which I figure must have been part of it. Knowing now that there were so many that look similar, I agree, it must have been something Porsche supplied for the dealer to install, or they had a supply deal with an aftermarket co.
I don't remember alarms being really prevalent until the early-mid '90's. Seems like that's when the sound of alarms randomly going off in parking lots for no reason, and at all hours, suddenly became common.
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Not a factory piece.
But alarm sounds good.
Making this the light to the machine that goes, 'ping!'... among other curbside noises.
http://www.youtube.com/watch?v=arCIT..._safety_mode=1
By the way, my radar detector antenna unit was mounted in front of the drivers wheel well on top of the air cond. condenser, which eventually vibrated a hole in it, necessitating
replacement. I would check to see where yours is at, there was a ribbon cable that could be traced to it in the front trunk. At some point, I am planning on completely eliminating the holes to remove all traces of both.
