PPI Advice
there might be a couple good tips from the 964 DIY section:
PPI Checklist
PPI Checklist
J
You can't see if the DMF has been updated without dropping the engine and splitting the engine / tranny. You can only find a record of it being updated.
The rattle is clue that it is the original and on it's way out. Good luck, fingers crossed!
I asked them to look and they said they would "try". Unfortunately, I don't think I am going to find much paperwork on this car.
(Fingers and toes crossed!)
J
I read a 964 buyer's guide in 911 & Porsche World magazine the an experienced technician could see through access holes under the car to see if the update has been done. The new flywheel will have a bolted on starter ring gear instead of a welded on one.
J
J
I am making a note of this. Thanks for correcting me~
I have also learned that U.S. Porsche dealers' records are not centralized unless it relates to a federally mandated recall. If the owner's manual is there, you could look up the original dealership and ask them to check if they did replace the DMF or added a head-gasket. Worth a shot. My car's dealership is long gone (Bayside Porsche in Seattle) so I'm SOL.
Also my rattle upon shutdown could be a sign of impending DMF failure comment... please ignore that as I am going to remove it from the earlier post....
Could be one of many things, could be totally normal.
https://rennlist.com/forums/964-foru...turned-of.html
Excellent!, my wrench was unaware of this, and he is quite experienced.
J
Joe,
If the PPI fails, here is a back up 964 from Winston Salem
Red 93 C2 Cabrio for 15K
Miles are on the high side but looks decent from the photos.
I wonder how the top is.
http://raleigh.craigslist.org/ctd/2181450914.html
John
John
Joe:
Do I understand that it's $225 for the PPI including leakdown? If so, that's a heck of a deal. Even if it's $100 plus $225, that's still a good deal. I looked at a 964 cab in VA near DC, his shop wanted $550 for the same service (prob market-area-driven). I passed on that one (for other reasons). The Porsche dealer who I ultimately bought my car from also wanted some crazy amt. (~$900) for a PPI with leakdown. They acted like they'd never heard of a 'PPI' before. It was long-distance and I knew no other shops in the area, so I rolled the dice and went without. I ended up going without, and it worked out okay. I had been looking at 3.2's originally and had 2 other cars checked out. One had leakdown's of 5-7%; the other was 5-8%, with one cyl. at 20%. Both owners swore they ran smooth and strong. I passed on both for different reasons, but I might have bought the 5-7% one otherwise. The 20% one, I don't know... This is where you have an advantage being local to the car. They told me the leakage was from an exhaust valve. If the car has been too sedately driven, I was told that could just be carbon. If I were local and I could talk somebody into giving it a long, spirited drive and then retest, I might have gotten much better numbers. Tougher to do long distance. There are only so many hoops most owners will jump through.
This assumes that they conduct the leakdown correctly, of course. I've seen a couple PPI's where the numbers were wacky and useless, which was a shame for the buyer to have paid for a leakdown by a tech who was unfamiliar with the process.
One point about 'body/chassis' stuff: it's been my observation that most mechanical shops can be trusted to spot suspension and undercarriage corrosion, but when you get into bodywork, paint work and "dents/dings", they are less confident because that's really not their "thing". They may miss or gloss over things. A body shop that works on Porsche's is best for this if you're compelled to find out definitively.
Laker, yes..It was just $225 with leakdown and compression!
It was a good thing I did that too! EuroWerks was great to work with. Jim did my PPI and was very thorough and spoke with me for over 30 mins after to discuss the results and what it all means.
I have created a new post with the results.
J
J
Joe,
John
John
J
J
goodLuck.
