964 Forum 1989-1994
Does 993 headers fit to the 964?
Old 01-21-2011, 04:55 AM
Mikke_Possu
Mikke_Possu's Avatar
Default Does 993 headers fit to the 964?
Hi,
Like title says, does 993 headers fit to the 964 without any modification?
I have thinking to buy these headers and use custom made muffler.
http://www.fvd.de/de/en/Porsche-0/99...eating%29.html
Thank you.
Old 01-21-2011, 09:06 AM
Geoffrey
Geoffrey's Avatar
The exhaust manifold / heat exchangers from a 993 do not directly fit a 964. The flanges are oriented 180 degrees differently on one side. If you had 993 cylinder heads, or 9M heads that have all 4 corners drilled for exhaust studs, then they would bolt straight on. You can have a company cut the flanges off and rotate them 180 degrees, but it requires a jig to ensure they are welded properly.
Old 01-21-2011, 09:34 AM
Bill Verburg
Bill Verburg's Avatar
here' is a set of 993 headers which have had the right(left in pic) side flanges flipped 90* to fit 911 or 964 head bolts
here's a set of stock ones ,again the right(right in pic too) side flanges are 90* off from previous
993 heads are set up for either orientation
993 head
964 and older heads are only set up for a single stud pattern
the exception is 964 RS3.8 which used 993 type headers and head exhaust stud pattern
964RS 3.8 type head
Old 01-21-2011, 09:57 AM
SuperUser
SuperUser's Avatar
Bill,
You have great pictures of every Porsche part!
Old 01-21-2011, 10:24 AM
Mikke_Possu
Thanks Geoffrey and Bill for fast and clear answer.
Old 01-21-2011, 10:35 AM
RacinToday
RacinToday's Avatar
Bill: Now that is what I call an answer and graphic example. Nicely done.
Old 12-21-2011, 10:44 PM
PChar
PChar's Avatar
Sorry to resurect this old tread, but I am very interested in fitting a set of 993 headers to my 964. Based on what was said above,.. can one easily fit 993 heads to a 964,..???
Old 12-21-2011, 10:53 PM
Laker
Laker's Avatar
PChar, have you seen this CL posting (no affiliation)
Old 12-21-2011, 11:50 PM
race911
race911's Avatar
"May or may not work with the stock cats and mufflers.............." There's an understatement, given stock 964 exhaust routing versus any 911 header system I can think of.
Old 12-22-2011, 12:16 AM
PChar
PChar's Avatar
I did emailed this clown a while back,.. and he sent me an exact photo of the fabspeed headers exhaust system. This may be a scam or someone looking to make a quick buck...
Old 12-22-2011, 04:28 AM
Laker
Laker's Avatar
OK just throwing it out there.
Old 12-22-2011, 09:32 AM
Bill Verburg
Yes, easy but not inexpensive. You need the heads, cam carriers, cams etc. It's worth some hp due to the bigger valves.
The 993Cups were built on 964 bottom ends w/ 993 top ends
Old 12-22-2011, 10:44 AM
PChar
PChar's Avatar
Thanks Bill, you have quite of an extensive expertise over exhausts and brakes as well from what I have been reading. Do you have experience or have heard anything about the Steve Timmins 993 HE with flipped flange for the 964? If so could you provide input? I have exchaged emails with Steve a while back about his system which would use his Craby Muffler as well, he was supposed to send me a sound bite of his system. I know he is a busy guy, and may have not got around to doing it, but I am very curious of how this set up perform on a 964.
Stephane
Old 05-10-2013, 09:40 PM
tacomaworld
tacomaworld's Avatar
Default Going the other way
I have a 964 with an aftermarket exhaust that sounds great.
I just bought a 993 that has motorsport option but does not make enough noise.
From what I gather, the studs have to be offset 90 degrees when trying to apply a 993 exhaust to a 964. But going from a 964 to a 993 ought to be a direct fit. Right?
Old 05-10-2013, 10:49 PM
HiWind
HiWind's Avatar
Bill thanks for the pics
Quick Reply: Does 993 headers fit to the 964?
