Speedo signal from ABS sensor
Then 964 speedo signal comes from the front left ABS sensor and is converted into a speed signal.
Is the signal converted just by the ''control unit frequency converter'' (964.618.220.00) or also by the ''abs control unit'' ?
Starting sometime in 91, the speed signal goes through the abs control box. Don't know if it works in conjunction with the referenced converter or not but I don know the signal won't transmit without the correct abs brain.
Here we go - post 91 ish cars use the front left ABS sensor signal. passed through the ABS control unit to the frequency convertor (964.618.220.00 for a C2 and 964.618.221.00 for a C4 I think), this signal is fed to the Speedo. Check out this https://rennlist.com/forums/964-foru...hangeable.html and the post referred to within it.
The signal from the ABS sensor to the ABS control unit is a sine wave produced by a mag sensor. The signal going from the ABS control unit to the frequency converter is a square wave (digital, 5v I think, may be 12v, I cannot remember).
I doubt the signal would drive the mechanical speedometer in the 931.
An '89 electronic speedometer from a 911 would fit in the 100mm cluster...(but the clear plastic face is flat not pointy).
