CCU Fault Code 16
I don't have a #16 listed here on the OBD1 list...
http://obd1interface.com/obd-codes/#more
if you get an answer, let me know so I can update the resource.. thx.
Technical Guru
Do you have the software revision number from the HVAC controller? I think fault code #16 is actually the oil cooler temperature sensor fault code. Its listed as #21 in the workshop manuals.
Oil cooler temp.
sensor
Short to ground or
open circuit short to ground
or open circuit
1. Check resistance between G 18 and G 12.
Specifications: at 60' C 3.6 to 4.0 k.o.
at 85' C 1.4 to 1.6 k.o.
at 100' C 0.9 to 1.0 k.o.
2. Ground must be present at G 18 when the connector is connected.
3. G 12 must not be connected to ground
Oil cooler temp.
sensor
Short to ground or
or open circuit
