More than average oil leak?
Take it to the dealership and have them throw it up on a lift and see what you can find out. It may be a simple gasket that has completely failed or you may be in for a top end rebuild. Has the motor ever been rebuilt? Have you had any of the critical gaskets replaced - if it's all 20+ year gaskets in there you may have to spend some time or money or both to address the issue.
I would expect to see a few drops of oil after driving. I had a 90 C2 that leaked like a SOB and I had to get that motor rebuilt and it was fine after the rebuild.
Is the oil in the picture a result of a normal drive (1 hour cruising around)?
No, no the oil is that from after 2 weeks of driving and sitting.
moffman , you should start a "show us your oil drop " thread , 122k miles on mine & purchased without inspection after 1 test drive so don,t feel bad , they may throw up the obvious but they,re not a warranty
will photo my drop when i get chance
