Tiptronic. from Neutral to D, clunk - no drive
posted on the 911 UK forum also
so this happened during rush hour, was on a hill, moved from N to D and clunk then no drive. In any gear 1,2,3 R the engine revs freely with no forward drag - even Park has no hold. Actually going from D to Park you can hear a grindy kinda noise for a second or 3.
So the AA have relayed me home and as the car is being dragged onto the flat back I can see the nearside driveshaft hanging down at the point where it meets the gearbox
its too dark to see anything more at the moment, but I am hoping it some kinda coupling and not a drive shaft spline (stuck even) or gearbox internals like the diff.. does anyone know the mechanics of this area in depth that can offer any advise.
With one axle hanging , the dif will spin the disconnected output and you will get no power out to a wheel .
Good news, well sort of! The 6 hex bolts where the drive shaft flange meets the gearbox flange had come loose. I never took pics but have found a suitable pic on another thread I have borrowed to show.
The bad news is 2 of the bolts have sheared off, I guess those 2 were taking the strain and finally gave up. The good news is I have reseated the shaft, tightened the other 4 and the car works OK with no Diff or CV noise/damage. Am calling the OPC to see if they have replacement bolts, then am gonna have to drill out the remaining threads from the inner flange!
