Wind noise passenger dash
Prior to dismantling my dashboard has anyone else experienced any significant wind noise coming from the passengers side dash local to the door?
(UK spec car)
Nothing at low speeds but as soon as I hit 60ish it gets pretty loud and annoying....
(UK spec car)
I used to have a good old whistling wind noise from the passenger side. It was particularly annoying at 120+ . I put new door seals on and now it's good for 140 (not had the chance to try it at any higher speeds yet).
I have it too on my drivers side. thought it was the hood at first but after a good listen on the motorway it is definately coming from the corner of the dash near the windscreen.
lee
lee
Lifetime Member
Lifetime Member
There should be sealant in this area -
If it hardens and fractures, you can get a really annoying amount of wind noise that can be very hard to track down.
I'm getting an annoying wing nice from the driver side also. Can't really tell from your picture. Do you have a part # or a close up picture? Thanks
Lifetime Member
Lifetime Member
No, but if you pop the trim off the door top, it's easy to spot the black mastic-type sealant and perhaps even see if it has cracked. I found it (after a LOT of experimentation) by stuffing first a cloth and then lots of Blu-tak into the area. Both of these cut the noise considerably, then I spotted the split in the mastic that was the culprit.
