964 Forum 1989-1994
964 Lightswitch ?
Old Nov 7, 2010 | 03:37 AM
falcor's Avatar
falcor
Default 964 Lightswitch ?
The bulb in my lightswitch never lights up.
When is it supposed to be on and off? Does it come on with the interior lights when you open the door or does it come on when you turn the lights on?
I've changed the bulb but that didn't help...
Old Nov 7, 2010 | 04:48 AM
koenig_roland's Avatar
koenig_roland
Same problem. I just replaced the bulb some days ago, but it doesn´t light up too...
Does your cigarette lighter lights up.?
Thx
Old Nov 7, 2010 | 04:52 AM
John Boggiano's Avatar
John Boggiano
Lifetime Member
The lightswitch bulb doesn't illuminate, although I seem to remember that there's a fairly easy mod you can do that makes it illuminate when the headlights are on.
The cigarette lighter itself doesn't light up either, just the socket it goes into.
Old Nov 7, 2010 | 05:26 AM
Harry Apps's Avatar
Harry Apps
Search is your friend. The bulb was not fitted because of annoying reflections in the side window. It could be fitted if required.
Old Nov 7, 2010 | 06:00 AM
freedman's Avatar
freedman
The OP says hew has fitted the bulb and it still doesnt light up
Old Nov 7, 2010 | 08:57 PM
Makmov's Avatar
Makmov
Mine is the same.
Never works, I have replaced the bulb. I am presuming its in the switch, which is $100.
Old Nov 8, 2010 | 12:30 PM
Kuchar's Avatar
Kuchar
https://rennlist.com/forums/964-foru...h-lamps-2.html
