964 Forum 1989-1994
Switch Lamps
Old 04-26-2006, 08:02 PM
stevepaa
stevepaa's Avatar
You can replace the bulb.
First pry off the cap, not shown.
Then use some heat shrink tubing along with needle nose to grab the bulb and pull.
Replace with new one.
Old 04-26-2006, 08:29 PM
MarkD
MarkD's Avatar
you da man!
Old 04-26-2006, 10:53 PM
botoo
botoo's Avatar
Not on mine, it won't work. My bulb is not burned out. There is no wire to the terminal on the switch.
Your bulb puller is great, however. I never thought of that.
Old 04-27-2006, 05:28 PM
stevepaa
stevepaa's Avatar
Mine was dead, but the good replacement does not light up.
So how do you get the switch out of there?
Old 04-28-2006, 01:14 AM
RickEtheridge
RickEtheridge's Avatar
Thanks Stevepaa,
That's what I was looking for. Now I can get it out and see if it is good or not.
Thanks again,
Rick
Old 04-28-2006, 05:43 AM
jenskleis
jenskleis's Avatar
Hi guys,
The illumination of my switch does not work (I tried to change the bulb).
Anyone know how to draw the wires to make it light up?
Jens
Old 04-28-2006, 12:34 PM
stevepaa
stevepaa's Avatar
I'm working on that this weekend.
Old 04-28-2006, 01:36 PM
anewbill
anewbill's Avatar
My 91 does not light up either. I think I heard on the board several years ago that the factory disabled the switch light because it caused a glare in the side mirror and was distracting to the driver.
Old 04-28-2006, 10:07 PM
ttAmerica RoadsterAWD
ttAmerica RoadsterAWD's Avatar
93 model...no light for me either.
Old 04-29-2006, 09:00 AM
Heirsh
Heirsh's Avatar
No light on headlight switch. I thought it was a burned out bulb!
Another thing to get around to to fix.
Old 04-29-2006, 09:07 AM
DarrylH
DarrylH's Avatar
https://rennlist.com/forums/showthre...t+switch+light
Old 04-29-2006, 12:37 PM
stevepaa
stevepaa's Avatar
Yes, there is no wire to the backside of the switch. I wonder if I can rig it to light only when the lights are turned on?
Old 04-29-2006, 11:19 PM
psychoideas
psychoideas's Avatar
Really sorry to hijack,
Can someone tell me, Does this light switch turn the lights on by pulling it out or by turning it???
Crazy I know.
Frank
Old 04-29-2006, 11:51 PM
stevepaa
stevepaa's Avatar
Turning it to the right in two steps.
Old 04-29-2006, 11:55 PM
stevepaa
stevepaa's Avatar
If anyone desires to make that light work, you will need the special connectors in the plug receptacle. Then you can wire out from 31 to ground for constant light or for switched light, you can run 31 to the switched portion of a relay and run a line from 56K to the coil side of the relay. Then the light will only be on when you have switched your lights on.
Quick Reply: Switch Lamps
