Two DIY's few questions.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
If I disconnect the battery I'm guessing it will definitely mess up the clock so how do I reset that into the correct time, and does it effect the radio I read sometimes the radio will ask for a code on startup but I think thats for the newer car models... (I also have an after market Alpine radio so I don't see how there will be any issues)
To reset your clock feel around on the upside down 'ledge' directly underneath your clock, you'll feel a rocker switch with one side popped up and one side flat against the dash. Push the 'popped out' side to adjust the clock, if you have the battery disconnected for a significant length of time hold the button down and it will start to move the minute hand very quickly.
No need for a code with an aftermarket radio.
I appreciate the help I just have one more question ![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
+1. My PO was the original owner, and there are three service tickets mentioning complaints about the glove box door. Even after three tries, the dealer did not get it right, and to this day it is difficult to get it to open. I suppose I should be grateful it is not the other way (popping open).
