964 Forum 1989-1994
FVD throttle body replacement 71mm
Old 10-27-2010, 05:39 PM
NineMeister
NineMeister's Avatar
Originally Posted by GT TWO
Interesting stuff.
Mine has upgraded TB, cams, head work and a chip and I have several dyno prints for 290ish bhp 265 at wheels.
I will have something built next year, probably a 4.0 on throttle bodies as I just can't help myself
It's a disease. Welcome to the club.
Old 10-27-2010, 05:46 PM
NineMeister
Originally Posted by evoderby
Hi Colin,
Thanks for your indepth contribution to this thread. Very much reminds me of a David Vizard quote: "I don't have opinions....just a flow bench and a dyno".
One question arises:
<<completely limited by the shape and turn of the intake rubber elbow; by substituting this for a large radius bend I managed to find another 4-5hp and equalised the performance with either the 68mm or 70mm throttle body. At the time I considered making a custom carbon intake pipe to replace the stock elbow, however further tests showed that we could achieve similar results with a longer intake pipe which stabilises the flow after the filter & builds up more velocity in the tract before the elbow. With the revised long pipe design we found 3hp & reduced the difference between stock & 70mm TB to around 1hp.>>
What would have been the outcome of combining the two e.g. elbow + intake pipe? ;-)
Cheers,
Harald
I did make a one-piece pipe with two long radius bends in aluminium to initially test my idea and this is how I found the 4-5hp. The problem with this design is that it was complicated to make because I would have to incorporate the breather pipe & idle valve stubs and furthermore fitting it was a pain. In the end I simplified the design to the one shown and achieved 70% of the result for 25% of the cost, so it was a commercial no-brainer as to which one we make.
The pipe will only fit a Motec equipped car which runs Alpha-N & MAP (without an AFM of any description), sold as part of the 9m Motec package, it costs £325 with K&N filter & support brackets.
Old 10-27-2010, 06:35 PM
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
Colin,
What is the little white plate blocking off in this photo?
Marc
Old 10-27-2010, 07:54 PM
NineMeister
It's a bracket to mount the Motec GM MAP sensor on.......
Quick Reply: FVD throttle body replacement 71mm
