Rocker panel / Door sill Rehab
Biggest challenge with this has been the parts list. Here it is:
These items are all related to rehabbing the side door sills (rocker panel) on my 1991 964:
Item Total Qty
964-559-296-01-01C-OEM 1 Rubber Trim
964-559-295-01-01C-OEM 1 Rubber Trim
964-559-293-01-01C-OEM 1 Rubber Trim
964-559-294-01-01C-OEM 1 Rubber Trim
999-049-007-40-M100 ~10 Plastic nuts (some may be reused)
999-507-373-00-OEM 6 shark fin (x2 ea) and front of door sill (x1 ea)
999-591-916-40-M260 12 Plastic Pins for door sills
Tools: Phillips screwdriver, 8 & 10mm small socket, 8mm box wrench, Glue to repair broken tabs.
Item Total Qty
