New Tyres - Sumitomo HTR ZIII
If you have 18", I would highly recommend the Goodyear F1 Asymmetrics. Better than the CSC3s, and far quieter. Also quite the value for money.
The Sumitomo's are good value for money for initial layout but they lose a lot of grip after first third of the tread is gone.
Fine if you are not a spirited driver.
As above, if you read the independant tyre tests, The Good Year asymetrics are a very good tyre. There are many good Bridgestones for good money here in Oz, one called the Adrenelin but not sure what equivalent is in US. If you aren't worried about a little noise. Dunlop Direzza Sport Z1's Starspecs are amazing. Phenomenal grip.
III's Grip is fine for my DD and as opposed to others I find the wet grip fine also. But noise is the same as every other brand I have tried. My car has nearly 90,000 miles so it gets driven and unfortunately I speak from experience.
I have about 5-6K miles on my set of Sumi HTRZ-III's. They are still very quiet and comfortable on the street. I have used them in 2 DE's and they are OK, but my gut (butt?) feel is that I liked the old Bridgestone S03's I used for the past 2 years on street and track. I will be using these tires for a DE at Watkins Glen and maybe one DE at Putnam Park this year, and I suspect they will be finished by the time to put the winter tires on. So, probably these tires get an "8" for value and comfort, but perhaps a "5" on Spirit. Next year I may try something else. (I should have bought the set of Dunlop Direzza's from DavisRiley... dangit)
BTW, I also have a set of Yokohama's on my other set of rims and they are very "crap my wheel bearings are $hot" loud. I'm a cheap bastard, so I put them on the car every once in a while to use them up. I ran one day of DE on them, trying to compare them to the Sumi's I used on the other day - hard to tell a difference, especially at my level of competency on the track; but I did manage to spin the car in T2 at Putnam with the Yoko's and while driving Flat Out.
I'm currently running Yokohama Neova AD08's and they are phenomonal. I've moved to a street tire class in autocrossing and love these tires. They are superior to many of the older design "R" tires I've used in the past.
There are lots of great tires out there (pick your brand, spend your money).... but I'm completely amazed by these tires.
I have 10,000 miles on my tires and they are still quiet, have lots of tread left, and grip really, really well in all conditions on the road.
You will not waste money buying these (street) tires! There are better tires out there, but you will spend $$$$$.
I switched after I quickly wore through by Bridgestone OS 2s (N3) tires.
After 10,000 fun miles with these HTR ZIIIs, I'll send the money I've saved on tires on maintenance parts and other upgrades.
There are many other battles for my money...
