Spare tire question.......
on my last 2 cars i carried tire sealant/compressed air & ran without a spare....and i do the same with 964.
i do not expect to have a flat & if i do i expect new sealant systems to work as effectively as my 19yr old spare!
As I recall, VW used to power the windshield washer, or some such, with the pressure from the spare tire. Topping up the spare required disconnect and reconnect. Perhaps this dual valve spare was designed to allow for topping up without disconnecting the down stream system; which, of course, we don't have!
I believe that it is to aid in re-collapsing the spare once it has been used. It states in the manual that this can take up to several Hrs. for the tire to return to it's original dimension.
Another, perhaps more poignant question: Has anyone actually tried to store the flat Road wheel in the 'Frunk'?
My car has oem 16" Design 90 wheels and it doesn't look to me that it would fit. Others with larger diameter aftermarket wheels may have even bigger (no pun intended) issues. I know there's always the back seat. But maybe owners should carry either an extra large poly bag (like the Leaf type) which the wheel will fit into and thereby not soil the car's interior with dirt, sand and brake dust, or carry a padlock and chain so the flat wheel can be secured to a sign or post so you can return for it later. Rambling thoughts.
Cheers!
Cheers!
It's crazy to think that if you get a rear flat, Porsche directs you to remove the front tire, place it on the rear, put the spare on the front, and then put the rear wheel in the tire bag...I'm calling AAA!
yeah, but it makes sense. I'd rather have a front tire support the weight of the rear than to have the skinny spare support it.
So, sounds like maybe that extra valve is to release the air when done?
At the end of the deflating the air flow is not so great that two valves would be called for . And its that last bit of folding up that takes time from my experience .
Burgled
on my 77 911S I put a rope around the spare with a piece of pipe and twisted it tight. The air comes out alot faster that way.
You realize the spare is an integral part of front end protection?
