Intake Manifold Stack question
#31
hmmm... not sure I totally follow this but I have my motor apart and currently I am at the stage of installing the intake stacks.
I bought the 993 part numbers and noticed the differences in how the injectors sit.. I have not bolted the fuel rails on yet to see if there is a problem.
But seeing as there is comment from the experts about power loss at higher rpm due to different sized outlets, I think I MAY go back to my 964 parts.
Here are some pics comparing how the injectors sit in the stacks... 3 photos of 964, then 3 photos of 993
![Name: DSC04800_zpsofdfpiz2.jpg
Size: 193.9 KB](https://rennlist.com/forums/attachments/964-forum/1197533d1501257705-intake-manifold-stack-question-dsc04800_zpsofdfpiz2.jpg)
![Name: DSC04801_zps8pcnbrex.jpg
Size: 205.4 KB](https://rennlist.com/forums/attachments/964-forum/1197534d1501257705-intake-manifold-stack-question-dsc04801_zps8pcnbrex.jpg)
![Name: DSC04802_zpsrfj2lby8.jpg
Size: 173.4 KB](https://rennlist.com/forums/attachments/964-forum/1197535d1501257705-intake-manifold-stack-question-dsc04802_zpsrfj2lby8.jpg)
![Name: DSC04803_zpssmukedyf.jpg
Size: 219.8 KB](https://rennlist.com/forums/attachments/964-forum/1197536d1501257705-intake-manifold-stack-question-dsc04803_zpssmukedyf.jpg)
![Name: DSC04804_zps1hys4rqk.jpg
Size: 198.8 KB](https://rennlist.com/forums/attachments/964-forum/1197537d1501257705-intake-manifold-stack-question-dsc04804_zps1hys4rqk.jpg)
![Name: DSC04805_zpsb0kilt3x.jpg
Size: 190.4 KB](https://rennlist.com/forums/attachments/964-forum/1197538d1501257705-intake-manifold-stack-question-dsc04805_zpsb0kilt3x.jpg)
#32
The fuel rail mounts fine and the clips holding the injectors also mount fine. There is no problem with the injector sitting a couple of mm higher.
As for the performance issue I dont see it and certainly my engine runs better. There is near perfect alignment between the inlet port and the stack...put them in place and take a look.
#35
Sorry to bring this old one back.
May I ask if it supposes to have "pop" when installing the injectors into the stacks?
How much force will be needed?
The reason why I ask is that I recently cleaned and reinstalled the injectors back to the stacks, now the car seems to be running lean. When I reinstalled the injector back, it was very easy without any need of force at all with all new o-rings. The injectors could move quite freely before putting the fuel rails. Is that correct?
Mine is a 1995 993.
Thank you.
Mine is a 1995 993.
Thank you.
#36
Technical Guru
I think it's been 7+ yrs since I did this job and I don't recall the feedback of the injector going into place, however I do recall I used a bit of ATF (automatic transmission fluid) on the o-rings as a lubricant during installation.
#39
in my case, no lubricant was needed as it was not tight at at.
The part number of the o rings is 94411090101.
#41
If you didn't take the stacks off to clean- or even if maybe you did- you have to remember that the type of gook and grit in there is hard and black....and usually for most people it's still in there after cleaning- because it's hard to see and hard to get out.
So there is that. Maybe something filled in the slot for the o-ring....
And then- another thing to remember, is they are plastic and when old, they are brittle- so make sure the loose one isn't broken or cracked (which is kind of like saying "broken or broken...lol)
But yes- they should snap in. If they didn't - and they are loose- you will likely leak. So be careful. You don't need an engine fire.
#42
If anyone is interested in 6 brand new 993 intake stacks, pm me. Just finished my engine build and decided to stick to my stock 964 stacks as they were in great shape. I also have the 6 seals needed but will need to double check. All purchased new from Porsche Marin and test fit only.
#43
If not, maybe someone else has some?
Thanks,
... Gregg
#44
Anyone out there have a set of inlet manifold stacks they would sell?
Thanks,
.. Gregg
