964 Forum 1989-1994
Top End Overhaul Questions
Old 08-24-2010, 07:57 AM
Cam Arnott
Cam Arnott's Avatar
Default Top End Overhaul Questions
Some theoretical questions for the brains trust
If you were doing a top end overhaul and replacing the cams with say Dougherty DC 21, new valve springs + Ti retainers, retaining Motronic would you.....
a) leave injectors in place as is
b) replace with stock new injectors
c) replace with new higher flow injectors
while you were in there?
Car has approx 125,000 kilometers, chip and G pipe.
Thanks!
Old 08-24-2010, 12:36 PM
Dave White
Dave White's Avatar
Don't replace, just send them out to be cleaned and flow tested. About $150, well worth it! One of mine was listed as "dripping", and I only had 80k miles. They will look and perform as new.
Old 08-24-2010, 12:44 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Dave is right: just send them out to a specialist to be tested & cleaned.
Performance software is matched to the engine's configuration and those cams do not need larger injectors.
Old 08-24-2010, 07:38 PM
Cam Arnott
Cam Arnott's Avatar
Thanks Guys!
Old 08-24-2010, 07:50 PM
carby
carby's Avatar
Thanks!
Nice....woulda, shoulda, didnt. I'll call you today if I get a sec.
Old 08-24-2010, 08:09 PM
Cam Arnott
Cam Arnott's Avatar
Thanks Mate!
Old 08-24-2010, 08:53 PM
KNS
KNS's Avatar
Where would be the best place to send injectors? Witch Hunter...? Others?
Old 08-24-2010, 11:11 PM
92silver964
92silver964's Avatar
Another source:
http://www.rceng.com/
Quick Reply: Top End Overhaul Questions
