964 Forum 1989-1994
Brake Warning Light
Old Aug 7, 2010 | 03:19 PM
ahmike's Avatar
ahmike
Cruisin'
Default Brake Warning Light
The brake warning light goes on after about 15 minutes of driving. Brakes are ok. When I start I notice the pump can run about 30 seconds after I turn on the switch before starting.
I have check over the system and I cannot find any leaks. Brake fluid changed last year.
Do I start changing out components? Will this show a fault code?
Mike
92 America Roadster
Old Aug 7, 2010 | 03:32 PM
jimq's Avatar
jimq
Burgled
check the switch on your emergency brake maybe?
Old Aug 7, 2010 | 06:38 PM
ahmike's Avatar
ahmike
Cruisin'
This is not the emerency brake light. This car has the turbo brakes with pressure assist. The light is above the emergency brake light.
Old Aug 7, 2010 | 07:38 PM
LouZ's Avatar
LouZ
From: Philly Area ----- George Washington took a dump in my backyard!
There is a "Brake Pad" warning light that could fluctuate if one of the 4 lines is not seated properly at the plugs next to the wheels. It wouldn't be worn pads, as that breaks the circuit and the light would be illuminated all of the time.
