Questions
Questions
I drove my wife's 964 yesterday while it was 90+ outside with high humidity. At highway speed the A/C was blowing nice and cold, but when the traffic came to crawl due to an accident, the air blowing from the A/C was as hot as outside. Is this normal?
Also, I noticed what sounds like a "Whistling" noise when the fan is on position 3 that would stop when I would turn left but comeback as I turn right (even slightly from straight position). The noise did not seem to go away by itself. Has anyone experienced this? My guess is thast it is the fan, but I cannot figure out why the fan noise may be related with the direction of the sterring wheel.
There is a small fan that blows air past the temperature sensor in the CCU. That one is a notorious squealer, and there is a thread on how to fix it.
It is normal for the air to blow a little warmer when idling. The compressor is turning slower, and there is less road draft through the condensor. It should be comfortable, and if it is not, there is a problem. Top candidates are:
Improper freon charge
Tired compressor
Dirt in the condensor coils
Tired compressor
The a/c fans are also notorious for squealing, I have fixed both of mine, one by replacement (ouch $ 750) the other by lubrication, but back when they were noisy, if I turned the steering wheel either to the left or the right, that would make them quiet for a monent, then the "music" would start all over again. I suspect that your fans are on there way towards a bit of maintenance. My theory is that by turning the wheel you put side load on the bearings and they go quiet for a moment.
Tired compressor
Tired compressor
If your AC becomes hot when the car is stopped, the most likely cause is your front condenser fan is not running, or perhaps only intermittently running in high speed (due to failure of the ballast resistor). Easy to check - engine running, AC on, check left front for air blowing out in front of tire. Steady flow of air = good. Intermittent high speed flow = bad resistor. No flow = failed fan/fuse/relay/....
I also had a problem with my system being overfilled with refrigerant and the High Pressure switch would cycle on/off while driving, with the result of little/no cooling.
Good Luck.
Good Luck.
1 Post
Good Luck.
Good Luck.
x2. When I first got my 964, the a/c would only blow cold at speed, not at idle. Replaced a/c condenser fan and no more problem.
