Fire Extinguisher Mount
I recently installed the Stable Energies mount (for power seats), not knowing in advance that it would interefere. Rather than 'bend' the slider handle as I read about somewhere, I simply removed the plastic '****' thing on the slider handle. The exposed metal of the handle makes contact with the mount now, but seems to have full travel to it's resting position, albeit against the mount.
I may attempt to grind out a notch in the mount, so as to eliminate the contact.
