Ignition Map Question
If the DME determines (and executes) timing based on engine speed and engine load, how does it determine engine load? Engine speed measurement is clear to me, but I have searched and not found how the electronics derives "load". Anybody know how it does that? Thanks.
Technical Guru
Load (in milliseconds) as an input to the various internal maps is based solely on the output from AFM.
"what I gather from your response is that "load" is a multi-variable input that is developed from the parameters you list."
Not correct, as was mentioned in a previous post, 'load' is determined SOLELY
by the AFM output. And an engine can have a load without the wheels turning,
e.g. as the clutch is initially engaged. Furthermore, torque is an output and load
is an input to a system.
