Upgrading front calipers.
For a cost effective upgrade without going big reds, is it better to go 993 front calipers to run with later 996 monoblock calipers.
The 996 discs are a good size but they are thinner at 28mm
I think 993 are 32mm
Also, does anyone know suppliers of brackets to convert 964 to either 993 or 996 calipers.
Cheers
Cheers
Cheers![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Cheers
964 front rotors are 298x28
993 front rotors are 304x32
993 tt/RS & 964 RS/t are 322x32
996 front rotors are 318x28
and they all have different o/s
here's a 996 and 993
![](https://forums.pelicanparts.com/uploads18/6_2_10_+0031280325305.jpg)
here's a 964 and 993, both are the big red 322x32 version
![](https://forums.pelicanparts.com/uploads18/DSCN56531280325328.jpg)
w/ the correct caliper adapter you can fit 993s to a 964, the same caliper adapter is used to fit either 993 or 993RS/tt big reds
Thanks Bill.
Sorry, I just re-read my post and it is misleading.
My question is. Is it better to fit 993 front calipers/discs to a 964 or can you also fit the 996 calipers/discs.
I assumed the 993 way is the better way to go as brackets are readily available (Would love a bracket contact if you know any one).
The 993 discs are the same size as 996 but 993 discs thicker so I also assume this is better.
The reason I ask is 996 calipers are readily available, especially in Australia whilst 993 front calipers are harder to get. I thought upgrading to 996 calipers and discs might be another upgrade option instead of doing the 993 caliper/disc upgrade but the more i read into it, the more it seems the 993 caliper/caliper would be better to do than upgrading to a 996 caliper/disc.
Thanks Bill.
next best is to get a caliper adaptor from VCI, discuss w/ them which rotor to use as the adapter and the rotor need to match
996 front rotors are 318x28mm
993 front rotors are 304x32mm
993RS/tt front rotors are 322x32mm
964 front rotors are 298x28mm
964RS/t front rotors are 322x32mm
