Weird brake issues - The sage continues. HELP!
Secondly, I know pumping the foot on a used master is bad news but it shouldn't be an issue on a new master unless you are an idiot and push it through the firewall and root the seals. (no seal rooting jokes please!)
I would hae thought that disconecting and disabling the ABS unit would be enough but if not, I guess we try to bypass it.
This problem was not there prior to master being changed however it did do the same thing with two second hand master cylinders that i tried so to me I am assuming it is not the master.
We were wondering about the booster.
How do we check that?
Thanks all....
If the abs unit is messed up internally , unplugging the electronics from it will not fix it .
"We were wondering about the booster."
I guess you have boost because the brakes grab at some point .
A bad booster causes a "heavy" pedal . You step down and the pedal takes more leg to do the same work . The pedal does not go floppy with a dead vacuum assist .
A test for a vacuum booster is , does it leak ?
Will it hold a vacuum ?
The guys are still regoing through it all methodically as such.
Rebleed several times with Motive Power Bleeder, cycling with hammer,pst. (Still not sure what that is but was recommended previously in the post and the mechanics knew what they were talking about. Assume it's some diagnostics test)
If still no good (where we are at currently) block master outlet to test master again.
Then if pedal goes rock hard, bypass ABS pump to see if that fixes it. If it comes good, I buy an ABS unit, if not, we're screwed as i have no idea what else it could be!
