964 Forum 1989-1994
Removing the Recycle Servo
Old 07-13-2010, 02:27 PM
gr1275
gr1275's Avatar
Default Removing the Recycle Servo
Can someone explain how to remove this? I did a search with no luck. I can remove the two screws but, can't seem to figure out how to release it from the damper lever.
Gary
Old 07-13-2010, 02:58 PM
Rocket Rob
IHI KING!
Rocket Rob's Avatar
If you mean the servos that control the HVAC, then I would follow the instructions on John's 964 page. They helped me when I had to remove mine. Be careful not to drop the screws.
http://porsche964.co.uk/technical/servos.htm
Old 07-14-2010, 08:20 AM
gr1275
gr1275's Avatar
Thanks Rob, You're right, I meant the recirculating servo. I used John's instructions for the two outside servos, but the one in the center attaches to the rod via a completely different means. I'll continue to ddo some searching...
Gary
Old 07-14-2010, 09:09 AM
Rocket Rob
IHI KING!
Rocket Rob's Avatar
Its been a few years since I did this. Isn't it attached via the same ball joint as the outside servos? Can you take a picture?
Old 07-23-2010, 12:10 AM
Pak_37
Pak_37's Avatar
Gary - this is a timely post - our recirc servo doesn't seem to be moving and so we're looking at trying to take it out - can't see how it comes out - wondering if you've made any progress in figuring that out?
Quick Reply: Removing the Recycle Servo
