secondary muffler heat shield - keep or toss?
It looks to me like you're confusing the CAT with the Secondary. That heat shield in your picture goes between the CAT and the left side cylinder heads attaching to the mounting points on the CAT.You can see the mounting points in the engine picture in the last post. Probably a good idea to keep it if you want your plug wires to last.
Hope that helps!![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Jim
Hope that helps!
Jim
thanks.
ketel
Cat gets pretty hot, so may be good to keep it. Do you have the plastic/foil covered shield that would hold the undertray? I do not have that anymore, so I keep the heat shield on the cat.
kos11-12 (03-20-2021)
