Placebo effect strut tower brace?
Installed a homemade towerbrace yesterday. The piece in the middle is made from an aluminium L shaped extrusion. The endpieces are made from some 4 mm thick aluminium plates. I wanted a brace that did not require cutting the compartment carpet so I fitted it fairly close to the fuel tank.
Driving impressions? Well, during very hard braking the car feels a little more steady and during turn in it is possibly a little sharper. Having said that I also think the car runs better after an oil and filter change!
eccentrically loaded ends... with a span of smallish cross-sectional modulus...
Well, it's helping a bit, but if you could make that span out of a hollow tube, you'd be getting a heck of a lot better resistance to compressive buckling (paper towel tube vs. dry spaghetti strands) for the weight. Also, simple-pinning that spanning piece at both ends would help keep any torsions/moments from pre-bending the span's ends - that helps the span stay straight & Strong!
But it's adding something to maintain your tub's geometry, to be sure.
"eccentrically loaded ends... with a span of smallish cross-sectional modulus... "
you're absolutely right elbee964, but I was primarily aiming to prevent the spreading of the towers during turn in. We'll see how it "turns out" (sorry but that was unintentional) on track.
OH! I didn't know that! If those struts are only worked to tension by tub flexure, then you've got a winning design.
However, that doesn't explain why some enterprising sort wouldn't have itched this scratch a long time ago with the strongest & lightest of pure tension-resistant elements; the rope.
My gut's telling me those tub towers move all which ways, including some compressive.
But if tension's predominant, then yours is a thumb's-up design.
Professor of Pending Projects
