Replacing a window motor
Need to replace one of the window motors and I was wondering if it is possible to do this without removing the entire window lift mechanism?
It's very easy once you take the door panel off. There are three screws, I think torx head, that you can access through the large speaker hole. A mirror will probably help in seeing things. I replaced one of the window motors in my 964. I was presently surprised on how easy it was.
Jim
Are you certain that a new motor is needed as I had a similar problem on my 993?
When my passenger window stopped going up/down from the swith, mechanic correctly diagnosed that a fault in the switch itself was the problem... saved me some money.
Cheers
Shaun
Cheers
Shaun
I wish it were that simple but first thing I did was try a working switch to check. Have had the problem for a while and just never got around to fixing it before the car went in for it's respray. I have even had the spare motor for a while after someone was selling both lift mechanisms on eBay and I noticed in the photos that both motors were still attached so I snapped them up for £40 and stupidly forgot to give them to the bodyshop to fit and by the time they rang and asked me about the window they had already put the door back together. They did however confirm that power was getting to the motor.
