Help required 9x17 Cup 1s
Hi, I'm looking for a set of Cup 1s and have come across the below wheels, the offsets seems a bit odd, does anyone know if/how they'd fit/sit on a 1991 C4?
Front: 965.362.124.05 7.5x17 et65
Rear: 965.362.128.00 9x17 et55
Any help would be appreciated
Cheers
Si
Cheers
Si
These wheels were on option fitment on the 968 and are not best suited to the 964. As mentioned above, 10mm (or preferably 15mm) spacers required at the front and even a small shim on the rears would be good. ET55 on 9J rears might make for a tight clearance of the oil line in the right rear. A small (5mm) shim would help.
Regards
Dave
Regards
Dave
Professor of Pending Projects
Si77 where are you located? I have a set for sale, but local pick up only... US$1K
https://rennlist.com/forums/7032999-post1617.html
